265 stainless brake line fitting advice
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Danny Danger, Mar 22, 2018.
  1. changing the front brake lines there's a 12mm nut on the solid pipe on the front but the actual rubber brake line is rounded near the connection how do they come off.
    Also the brake pipe sits in a bracket on 2 round clips, how do you get the brake line off to inset the new one as they looked crimped.
  2. well today has not been a good day. Does anyone know if the abs unit is behind the heat shield at the back of the engine. looks like i am going to have to run a new brake pipe to it
