A pair of PH2 225 standard drilled and vented front discs. These have been sat in the garage for a year after i changed to HC discs. They need a good wire wool rub down to remove the surface rust colour. You can see where i gave the top disc a quick rub. Renault part number 7701208843. Due to weight, £50 collected from Aylesbury These were bought for renault Megane MKII DCI but fit Laguna, Megane, Scenic, but check before you buy. Pagid 54139 vented brake discs (4stud) for the front with Pagid T1693 front pads. Both are brand new and have been sat in the garage. £50 for both, collected from Aylesbury. Postage would be quiet a lot so collection only
Just noticed i hadnt reset the vernier caliper.....the measurements are wrong. This is the correct one
