2 weeks in problems already
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by sen, Dec 5, 2017.
  1. sen
    sen
    car has started to make a weird noise. Sounds like I’m driving over a piece of metal in the road. Only seems to happen when moving forwards very slowly?
  2. Id start off by jacking up at each wheel, give it a shake and spin the wheel to see if you can hear a noise, then I'd be checking ball joints and see if your gearbox bolts snapped
    sen likes this.
  3. Do always get it when moving forwards? EG like in slow traffic, or just when cold and you 1st move off?
  4. sen
    sen
    When moving forwards at low speed. Doesn’t matter if engine has just been started or not.
    If you threw a steel rod on the floor and drove over it, that’s the sound it makes.
  5. sen
    sen
  6. sen
    sen
    Cou
    Could this noise have anything to do with the dash saying my o/s/r tyre pressure monitor is absent?? Is it possible it’s snapped off inside the tyre?
  7. That could be possible, jack it up and spin the wheel about both ways, see if you can make it rattle
  8. sen
    sen
    It was the tyre pressure sensor. Now do these have to be programmed by Renault when they’re replaced?
  9. Nope, should sort its self out, would recommend oem replacement
  10. sen
    sen
    Yeah will definitely get genuine Renault part. Thanks for your help. Most helpful guy on here.
  11. Most helpful guy on here, might be taking it a bit far, lol :tongueout: :smile:
