Rattles behind door card
Discussion in 'Megane Discussion' started by Chrisball35, Jan 16, 2019.
  1. Since the weather got a bit colder a very annoying rattle has started somewhere behind the passenger side door card. Its pretty constant especially on rough surfaced roads. Anyone else got this or anyone figured out what's causing it?
  2. Same when it's cold.. it's french
  3. Mine has the same annoying noise too..
    Any solutions please?
    Chrisball35 likes this.
  4. Interesting that it's on the passenger door for all of us. I just assumed a previous owner had taken the door card off at some point and not quite put it back on properly.
    Sounds like it might be a common issue though
  5. I have a similar rattle my R26 its something to do with the little square thing behind the passenger door handle on the outside of the car.
  6. I thought my passenger door card was rattling
    Turned out it was the plastic cover on the recaro that faces the door card.
  7. Interesting, was the cover just loose ? I only ask as I had a passenger in my car last night who put the seat all the way back. After she got out the car the rattle was a lot less noticeable
  8. No it rattles against the metal frame (sort of wares)
    I took it off and ran some anti rattle tape to any part it touched the frame
    I too was convinced it was the door card etc, took it all off and it was still rattling!
    Remove that trim and try it
    Mark B and Chrisball35 like this.
  9. Thanks I'll try that!
