Hello everybody.... I wanted to change my rear axle bearings today. Unfortunately the bearings do not fit !! They are too small .... has anyone ever had that? greetings Thomas
sounds like you have the 225 phase 1 bearing, 225 phase two and R26 are the same size, but the ABS rings are t=in the bearing seals so if you go aftermarket bearings your ABS will not work.
no no I mean the axle bearings !! not the wheel bearings / brake discs... my English is not the best , sorry these Set : https://ukwhitelineperformance.com/collections/all/products/kdt948-bushing-kit
