water in drivers side storage bin!
Discussion in 'Exterior & Bodywork' started by 1971designer, Apr 4, 2018.
  1. Hi all hope someone can help!
    have a leak all the time if i park the car half on half off pavement after heavy rain
    The storage bin fills with water,scuttle drains are clear etc so wondering if it`s the door seal at top of door or the one at the bottom?
    thanks in advance for any pointers!
  2. PS carpets etc are dry just the water is going straight into the bin
  3. I had this on my R.Water was entering via the door speaker, sealed, and problem went away.
    1971designer and Mikey4410 like this.
  4. I have had EXACT same problem(2008 r26).nearside up on kerb,i will tell you exactly what happens....the water goes along the window outer seal and into the wing mirror fitment and straight down into the door then becuase cars at the angle it will run straight down onto inside of door skin, down the door card and then onto door seal at very bottom and seap over that into car(again because of the angle)
    Have done a temp fix currently just to stop it coming in but i intend to remove wing mirror and block whatever path the water takes .
    1971designer and oldfella like this.
  5. Thanks matey i`ll have a look at the wing mirror scenario
    Mikey4410 likes this.
