Hi guys! I was wondering if i could fit thicker or thinner brake discs in my RS 265, ik OEM are 340x28mm, was thinking in fitting 340x30mm, 340x32mm I found ATE brakes discs, is it a good brand? - Can i fit VW Gti´s brake discs in the 265? - Does anyone know what bolt pattern should i look for when searching? - I´m also looking for the brake pads dimensions, what should i look for? - What is Minimum thickness, as its specified in brembo´s technical sheets? Cheers!
- Can i fit VW Gti´s brake discs in the 265? - No. Different overall height. - Does anyone know what bolt pattern should i look for when searching? - 5x114.3 - I´m also looking for the brake pads dimensions, what should i look for? - https://raceandrally.com/media/cata...fb8d27136e95/1/0/1001-11_-_pfc_brake_pads.png - What is Minimum thickness, as its specified in brembo´s technical sheets? - Danger! Do not use rotor if it thinner (<28 mm).
- What is Minimum thickness, as its specified in brembo´s technical sheets? - Danger! Do not use rotor if it thinner (<26 mm for OEM)
if any thicker than specified it won’t go in between the pads will it be a tight fit. Sent from my iPhone using Tapatalk
