Sunroof wind noise
Discussion in 'Exterior & Bodywork' started by Nathan Rees, Feb 9, 2022.
  1. Hi,
    I have a mk2 megane with a sunroof it had a terrible wind noise when I first got it. I replaced the little plastic wheels on the runner bracket and it has made it better. The wind noise was coming from the back but since changing the plastic wheels it seems to be coming from the front now? It seems like it’s closed ok.
  2. Hi, have you tried these:
    https://www.ebay.co.uk/itm/Panorami...2349624.m46890.l49286&mkrid=710-127635-2958-0
    I've just replaced mine and no more noise.
    Sent from my CPH2207 using Tapatalk
  3. Ok, If your previous wheels were stuck (as mine were) they can expand the track a little, you can replace the track but good luck getting the starbolts out (mine are rusted and about to snap).
    Have you tried treating / replacing the seal?
  4. Hi,
    where would I find the seal or is it a Renault only part?
  5. Apols, there my level of knowledge fades somewhat. May be worth contacting Renault parts direct and asking they seem good.
    The scenic seals seem to be about for around £20 on eBay, I believe (but may well be readvised on here) that the panoroof is the same unit fitted in both but again I'm relatively new to the megane...
