Basically bought a stud conversion kit for my mk3 rs, went to fit a set of calibre suzuka wheels to find the nuts won't fit in the holes, tried 17mm nuts but they still won't fit, any ideas? Thanks in advance Sent from my LYA-L29 using Tapatalk
you need tuner nuts. i have suzuka and you cant use std wheel bolts on the std set up.i suspect when you go to stud and nut kit you will need the tuner nut type.
