Hey guys, does anyone know if these values are the stock wheel alignment setting for a Megane III RS 265? I've used Pirelli Pzero slicks for two track days and the outer rubber from the front left tyre has been ripped off. Enviado desde mi SM-G925I mediante Tapatalk
Doesn't matter, you need at least 2.5 or 3 degrees of camber for slicks to work properly. Hence the outside should is ruined.
I won't be using slicks anymore! Do you see these values are from stock alignment? Isn't it 6.7mm toe in the rear too much? Cheers Enviado desde mi SM-G925I mediante Tapatalk
