[h=1]As title. Not going to be needed for the new car so I'm now selling this great harness. Original description: "The Profi II ASM professional 4 point clip in harness. Featuring anti-submarining (ASM) technology which is designed to reduce the risk of sliding under the harness in the event of a frontal impact. 3" wide shoulder straps and fitted with lightweight quick adjusters. The Lap Straps are 2" wide featuring clip on end fittings. Schroth's patented RFR lightweight quick release design buckle fastens and releases the harness." Dated until 2017. In great condition, only used for a handful of track days so very clean and unmarked. Comes with everything pictured (except my finger tip and the Megane...!) Would like £120 delivered to mainland UK. Can be collected from Moreton-in-Marsh or Gaydon. [/h]
Yes they can, details of how I had it fitted can be found here: http://www.rsmegane.com/showthread.php?t=466 The brackets I used were Schroth B23A from memory. Unfortunately I don't still have the ones that I adjusted to fit the car but it's a simple job.
I can see where you have adjusted (bent) the bracket nearest to the handbrake, is that a seat out job to bolt it in or can the seat be slided back for fitting ?
It's seat out (or as I did, it's seat undone and tilt forwards!). I'm happy to fit it for you if you buy the brackets and drive over to the Cotswolds
