pro race 1.2 mk4 rs
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Tricky401, Jun 4, 2021.
  1. will the following fit the mk4? i think these came from a mk3
    18x8 cb73.1 et35 5x114.3
    i have been in contact with rimstock and as stated in a previous post by somebody else they are out of production probably until next year
    is 8” wise enough as ideally i think it would be pro race 1.3 at 8.5” but that’s not an option as i can’t get hold of any
    will just need some reducing spigot rings to make it fit the center bore which is 66 if i’m correct?
    this is posted in the wanted section by mistake so mods please remove that post
  2. anybody help out on this? it looks like mk4 rs aftermarket wheels are a nightmare
  3. The 18x8 it's no problem, but I think ET 35 is too much! at least on MK3s... in MK4 I don't know!
    You can use reducing spigot rings without problems! the center bore it's 66.1mm
  4. ET35 will look like a monster truck without some decent camber, and even with camber it will probably ruin the handling.
    Standard wheels are 8.25 wide and ET65.
