Noise generator Megane 250.
Discussion in 'Wanted' started by Friggerpants, Jan 7, 2018.
  1. C0697AFE-3FB6-4405-B612-E35E37F800B6.jpeg It’s gonna cost me £10 for a alloy blank to blank off the noise generator hose, as I’ve now removed my aftermarket dump valve.
    If anyone’s got an noise generator they’ve removed, and will sell for a tenner, I’d rather fit that, to keep the OEM look.
  2. what has your noise generator and dump valve got to do with each other?
  3. You pull off the noise generator to install an aftermarket dumpvalve, and blank off the standard valve.
  4. but you must have blocked up the noise gen pipe that feeds the noise generator, when the DV was fitted?
