Hi Guys Running 1st track day in the Megane Sunday, running a set of R888s on OEM 18's 235/35/18's Whats the best pressures to set them, cars 1300KG with me with BC's running almost 3 degrees front camber, 2mm toe. Guides say 23 - 27 cold / 28 - 40 Hot. I remember years ago I killed a set running them to high so wanted to ask peoples opinions, I drive pretty hard so should I just aim for 30 PSI hot like I do with my Clio and AO50s? If so I normally run the fronts 21 PSI cold and that gets them to 27 after a session - Rears I use to run the Clio 24PSI cold and that got them up to 29 after a session Do you guys with Meganes and R888s pretty much see the same increase? or should I aim lower? Thanks in advance.
