Megane R26 - 281 BHP / 320 ft/lbs - 2008 (57) - £4500
Discussion in 'Cars For Sale' started by Northants172, Jul 31, 2018.
  1. I bought this car from another member here who will 'hopefully' vouch again for it!
    Cracking car - had a little issue with fuelling initially but solved with a replacement hose and N75 which has transformed it.
    Running 281bhp on a CGR Stage 2 Map (recently dyno'd) - Fabulous to drive - Took it for a shake down at Bedford (half day only) and it performed well. Could do with some uprating on the brake pad / disks / fluid to handle track use better, but other than that, very capable on track and kept up with much more expensive machinery.
    Here is a summary of the spec: PM me for a chat.....
    Stunning performance with the Stage 2 Map offering 281 BHP / 320 ft/lbs.
    1 of only 151 made in Glacier White with Recaro Seats in very good condition.
    A lot of money has been spent upgrading this car and the performance and handling is incredible.
    Engine and Transmission
    • 6 speed gearbox strong – no issues presented.. Limited Slip Differential.
    • Engine strong and clean. Does not smoke or use excessive oil.
    Stage 2 Map by well known tuning house - 281 BHP / 320 ft/lbs (rolling road tested April 2018)
    Cambelt Changed - 14/09/2015
    New R26R Clutch fitted November 2017 by Mark Black with Single Mass Flywheel
    CGR Decat
    630cc Injectors
    Aitek Intercooler
    Ikon Motorsport Inlet and Boost Hose
    Scorpion Exhaust
    KTR Induction Kit
    Polybushed Engine and Gearbox Mounts
    New N75 Valve
    New Crankshaft Position sensor
    Full service with Oil, Filter and New Sparks in last 500 miles by Mark Black. Plenty of history in the folder.
    Handling, Brakes and Suspension
    Standard R26 Suspension
    Powerflex Handling Kit fitted April 2018
    Lower Ball Joints, hub bearings and Hub Inserts sorted April 2018
    R26 Wheels in Gloss Black
    Michelin PS4 Tyres - 235/40/18
    Brembo 4 Pot Brakes
    Drilled and Grooved Disks
    CMC Rear Strut Brace
    Other
    R26R Spoiler
    Air-con recently re-gassed July 2018 and blows cold.
    Big Boot Mat - Rear seats removed but included in sale
    Private Plate R26 RGW included - valued at £350
    Cruise and ESP working as they should
    2 Keys
    Bodywork
    There is a dent to offside sill as shown in photos and the paint finish is poor on a small patch on the front of the rear arches (both sides the same from where the stone protectors were originally stuck on) - see photos. Overall bodywork good for the age. Nearside window doesn’t go down always, will try and address this before auction end. Front splitter loose in the middle.
    image001.jpg image002.jpg image003.jpg image004.jpg image005.jpg image006.jpg image007.jpg image008.jpg image012.jpg image013.jpg image017.jpg IMG_5678.JPG
    Big Uno and Canky like this.
  2. My Old Car. Can definately vouch for it a lot of work has been done to it!
  3. Reduced to £4000....
