What's the best gearbox oil to use in a 250. Cars just ticked over 87k and when its cold it sometimes crunches into second gear. I know when I had my clio 200 you could change it for a thicker viscosity and it helped massively. Cheers
i beleive 75w80 is ok that what i have put in mine PK4-013 gearbox which is the same as the 250 onwards. i also added wynns aditive for gearboxes which make it smoother gears. oil: https://www.opieoils.co.uk/p-205902-elf-tranself-nfp-75w-80-transmission-fluid.aspx Wynns additive if you wish: https://www.ebay.co.uk/p/1405891595...MIv6eSyZry5wIVibTtCh1xqwQmEAQYBCABEgJn7fD_BwE
Strictly NFP spec oil, the OE stuff is best for it need 2.4litres of the stuff https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F151621338495
100% agree. I do mine every 30-40k since new It’s got to get cooked at track and so far, so good! Sent from my iPhone using Tapatalk
