250 Front left wheel noise Video
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by sergio, Jan 27, 2019.
  1. Hi.
    I changed the suspension to CUP version with eibach coilovers and now make this strange noise amb I don't know where does it come from.
  2. you have fitted the driveshaft spacer?
    timbo likes this.
  3. No, what is it?
  4. 0 research done before you fitted them then? when you drop these cars past a certain point you need to fit a driveshaft spacer (might not be whats causing that noise though)
    Plenty of threads if you google
  5. -Jamie-
    Doesnt look hugely low tbf, Spacer isn't always needed either way if you have decent camber and aint running retard low.
  6. Charlie Howard
    What is the point you need a spacer? I've got one if I ever need it but not sure if I'll need them
  7. I think the problem is not that the spacer is missing. Maybe is a defective side shaft or light tigthten nut?
    Definitively i need to check all
