Forged Glacia White R26
Discussion in 'Megane Projects' started by L.maddern91, May 1, 2016.
  1. Forged Glacia White R26
    i thought id start a new progress thread as my original one wasn't updated enough and my plans have drastically changed, in the form of a fully forged T20 turbo engine build. Originally i got the engine from a forum member, the only parts i have kept is the turbo, rods and block. everything else has been changed, mostly out of peice of mind. sorry for the lack of photos as most of the work has been done in short periods of spare time.
    Engine Spec -
    T20 Turbo
    KTR Racing Engine Mounts/Gearbox/Torque Mount
    3" Turbo Back Exhaust
    ARP Crankshaft Main Cap Stud Kit
    ARP Cylinder Head Stud Kit
    Crankshaft "Big End" Bearings King Racing
    Crankshaft "Main" Bearings King Racing
    PEC Forged "H-Beam" Con-Rod Set
    PEC Racing Forged Piston Set
    Replacement Oil Spay Jets
    Seimens Dekka 630 Injectors
    Uprated MLS " Multi Layer Steel" Head Gaskets 1.30mm Thickness
    Gates Powergrip Timing Belt Kit
    Auxiliary Belt and Tensioner Kit
    TTV Solid Mass Flywheel
    Genuine R26.r Clutch Including Slave Cylinder
    004 External Fuel Pump
    Swirl Pot
    All New Seals
    Pace Front Mount Intercooler ( 4" Core )
    Mocal Oil Cooler
    Shirt shifter
    There Will Be Bits I Haved Missed
    Interior, Exterior And Chassis Spec -
    Sabelt Fixed Seats
    Sabelt 6 Point Harnesses
    Sabelt Side Mounts
    KTR Subframes ( customized to actually fit )
    KTR Harness Bar
    Custom Rear Bar
    Bc Racing Track Spec Coilovers With Solid Top Mounts
    R26.r Rear Spoiler
    Standard Wheels Powdercoated In .R Red
    New Brakes All Round
    New Door And Tailgate Looms
    Fog Light Blanks
    Xenon Conversion
    Again there will be bits that i have missed off.
    Other And Pieces
    Rebuilt Front End Using Genuine Parts
    Replaces Gear Linkage Cables
    Replaces Both Door Looms
    Replaced Boot Loom
  2. nice spec, where/when are you getting it mapped? be interested to see what the final results are.
  3. A new friend of mine is doing the mapping for me, hes a wizzard, comes very highly recommend, he doesn't let anything go out his work shop running anything less than perfect, hes expensive, but his customer services is next to non.
  4. Any pics
  5. I will get some photos up asap, cheers for that rear bar btw mate. I hear your off to cadwell in a few weeks with dan? I might be popping down
  6. I thought Rs tuning was doing it Lee.
    Lee
  7. Changed my mind mate
  8. You still doing your build?
  9. rear bar, did you have one off me, I can't remember, you know Dan do you ?
  10. Yeah lol, like 2 weeks ago? Im sure it was you yeah i kinda know him, was speaking to him on instergram the other day, said you guys was going down, so I thought i might pop down and watch
  11. Ahh yes, pop down bring a helmet and jump in with one of us for some passenger laps
  12. Where are you from
  13. Sounds good mate! Ill give you a text, think i still have your number.
  14. Scunthorpe mate
  15. You've got it now
  16. not sure now as I'm thinking of selling my Meg.
    Lee
    So before the engine goes in, starting tomorrow i thought id get her mot's as it was due within the month and emissions may ( will be ) an issue after.
    All was going well untill the steering/suspension tests, drivers side swivel bearings absolutely knackered. Because I haven't really driven her in a few months id had really noticed.
    Ironic really as i was only just speaking to dan about having them done out of precaution anyway, quick text and bearings should be with me in the next few days. Appreciate it dan.
    Front end will be having a complete refresh at the same time.
    This will basically be a new car by the time its finished
  18. A few photos of parts i found on my phone
    The postman literally chucked the intercooler out of his van and damaged the pipe work
  19. Be interesting to read this as I'm also planned a forge engine build.
    Currently have the engine and forge rods.
  20. So the base map has been loaded, and the engine is been taken out as we speak.
    Also ordered a complete front end suspension/steering refresh from renault.
  21. What cooler is it?
  22. Custome made PACE intercooler mate
    James likes this.
    Engine is out
    On a bad note, my work car got broken into. Stole my wallet, work bag & 4 tins of tuna
  24. MBC
    MBC
    4 tins of tuna! In all fairness it is quite pricey these days. What tossers!
    Bowen likes this.
  25. looking forward to hear more about the results.
  26. Off down to check on the progress in a hour or so once the postman has been. Will update
  27. Nice keep it coming
    John
  28. Well today we got the engine in, and running ( ticking over ) tomorrow the rest will be built up, still need clutch bleeding and a few pipes put inplace
  29. Quick update. The clutch is a been a twat to bleed, thats the only thing im really waiting on. Then its coolant pipes and front end on.
    Thanks lee for popping down. Nice a45 btw [emoji16]
    Lee in scunny likes this.
    Got her started this evening, after abit of hunting, coughing and farting she finally idled properly after all the sensors was zero'd. Al seems good, just need to get the front end on tomorrow and run her in
    So my brand new LuK slave has shit itself after 20 miles.
    Few problems with boost at the moment, but soon to be sorted hopefully.
    Cheers andy and chris for the speedy replys
  33. I know your pain with the slave, I had 2 in 2k, royal pain in the arse, any idea why yours has failed?
  34. Not sure yet, think its just to so with the higher clamping force. The LuK ones are sort of in two parts were the Valeo is one complete unit. Think its just split. Will be ringing LuK and engine dynamics tomorrow
  35. I had 2 luk slaves go in 2 months.
    They was the older plastic type though.
    Both leaked from the O ring where the pipe joins the slave.
    Was yours one of the new metal ones?
    Just wondering because I've just brought one so might fit a bigger O ring before I fit it.
  36. matt e
    stay away from the LUK slaves then?
  37. Mine was plastic mate. Yes stay away from LuK slaves. Will be sending a an email tomorrow, cost me even more labour... More oil
  38. I'm sure I read on here that the metal ones were a lot better.
    I'm going to take the pins out and have a look at the seal now.
  39. Maybe so mate.
