just trying to order some new front pads from camskill. which part number is it for the fronts only. is it FCP1667H http://www.camskill.co.uk/m49b132s4...RAKE_PADS_-_FCP1667H_Ferodo_DS2500_Brake_pads this is the ones im looking at. also who was the man with the replacement caliper pins?? gonna attempt to replace these myself. not done it before. any hints tips? what tools are needed anything out the ordinary. i have seen copper slip is needed? this goes on the back of the pad i take it? should be interesting fitting these hahaha
its easy, take wheel off, take care knocking the 2 pins out, might need a hefty whack, take out old pads, push the pistons back, put a dab of copper grease on back of pad, put new pads in, put a bit of the grease on the collars of the pins and refit, give the brake pedal a few pumps, job done, 10 mins per side : )
the pads are probably cheaper from jjc race and rally, you need to phone them to order, but great service.
