Fast road setup
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by tommy80, May 1, 2022.
  1. Hey guys
    New here and new to suspension so bare with
    Looking for help with a fast road setup
    But looking for something that has great straight line grip and great on the b roads
    Would neg 1.4 on the front and 0.05 toe be a great setup
    Also do you guys think it would be best to have a slight drop in camber on the driver side due to more weight on the driver side
    Thank you for any help
  2. That will be fine for fast road. Coilovers? Id keep camber identical, and set rideheight symmetrical left to right, and have some rake with the back 15-20mm higher
  3. Hey mate yeh bc
    Ok thanks man
    The only trouble is finding that middle ground between straight line tract and handling
    But if you say thats a good setup will get that booked
  4. How much power are you running? I run around -1.5deg negative with 378hp and its alright in 3rd gear upover.
    If you want it to corner better theres always a trade off sadly but -1.5deg is not too agressive, with decent rubber you should be fine, assuming you have lsd box.
  5. Around 320 so it should be fine
    Yeh running and LSD and pilot sport tyre
    Thank you for the help
  6. Hey mate forgot to ask
    How much camber and toe in should you run on the rear
    Will have to get some shim
  7. Ive not messed about with the rear yet so might need a bit of research as to how you want the car to respond, i left mine stock.
