Hello In 2013 august I started to transform my 225 cup to a drag car and aim for the top After 16 months of hard work we allmost finished the car. 2 months to go and we are ready to break records.
Now i have 600 hp on 1.8 bar on fuel pump. In two months the tuner comes and he will finish the job. 3 bar on precision 6466 with c16 race fuel. After that i will put new videos on youtube. The car was taken appart over 6 months awaiting for parts. I will put pictures but the forum limits me to 1 mb per picture.
Until then here arr the mods Megane 225 engine. Standard crank ( billet after 800 hp ) Je piston 83 mm fsr Zrp heavy duty h beam + 625 arp bolts Athena gasket 0.85 mm Arp head stud +main stud Acl racing bearings big end + main Catcams turbo stage 2 camshafts Pipercroas hydraulic lifters Catcams spring valves Supertech oversizedbinconel valves 1.5 mm intake / 1mm exhaust Ported head race version Compression 9:0 Sqs 4 gear drag dog box vag Sqs lsd Custom dual clutch 900 nm mtx racing Custom driveshats hungary Sqs sequential 4 speed shifter Flat shift no clutch Precision 6466 ar 0.82 Precision wastegate 46 mm 4 inchi downpipe Haltech ecu Iq3 dash Aem smart coils Haltech 4 bar map + many sensors Bc coilover kit Powerflex black series all of them front and back Sassa 6 point rollcage Custom wheels 15x9j et -30 26/10 15 MH drag slicks Custom 300 mm disk with standard brembo caliper to fit 15 inchi rim 4 sensor egt 2 senzor afr Knock kit prevention Car 1050 kg Aiming power 800 #850 hp at 3 bar of boost or lower
wow friggin awesome, where are you from sabinhh??? if you got any uk dates can you pm me so I can come see you do the business, good luck with the records amigo
