Hi, someone can confirm me about caps diameter on these original 19" wheels I fit on my Cup: I have to search them online (total black if possible) but i need exactly the meausure. Thanks to all.
This is what you need. Size I'd guess is 57mm https://www.renaultpartsdirect.co.u...t-clio-megane-rs-wheel-centre-cap-403156891r/ Sent from my SM-G950F using Tapatalk
57mm or 60mm normally. Measure it if in doubt but that's the cap you need [emoji846] Sent from my SM-G950F using Tapatalk
Just measured - 57 mm ext/53 mm int. So 57 mm is the correct size. [emoji1303] Inviato dal mio iPhone utilizzando Tapatalk
