Cam belt service
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Nitro94, May 5, 2021.
Tags:
  1. I’m getting my cam belt service done in a couple of weeks. I’m supplying all the parts to my mechanic that I need. I’ve brought the cam belt kit, aux belt kit and water pump of RPD. Anything else I need to get for this or is it all included in the kits?
  2. matt e
    make sure they have the correct timing tools
  3. The garage I use is a french car specialist garage. Are there any tools specific needed for the RS that the garage likely wouldn’t have?
    Also just want to double check that everything is included in the 2 kits, I don’t need to buy any bolts or seals?
  4. Might be wise to get a dephaser pully, its something i always do.
  5. Camshaft oil seals if there leaking but you won’t know until you take the timing cover off. Camshaft end plugs
  6. exactly this, change plugs and oil seals anyway and for sure dephaser pully
