Bumper has dropped
Discussion in 'Exterior & Bodywork' started by lholand421, Dec 29, 2014.
  1. I've noticed that under my passenger side headlight my bumper has dropped a lot. I have tried pushing it back , lifting it but it just drops again.
    I'm guessing the brackets behind have come lose ? Anyone else had this issue ? Any quick fixes ?
    Images should be attached :smile:
    Thanks all !
  2. Take the bumper off mate and replace the pop riveted brackets with nuts, bolts and washers
  3. Cheers going to give it a try :smile:
  4. Had a look today and the bracket under the drivers side has snapped :worried: will be ordering a new one from Adam greenhouse :smile:
  5. Got any pictures with the bumper off. I may need to do the same.
  6. I've got some, I'll be doing it again when the part arrives so will take some and fire them up :smile:
  7. sorry to jump on this thread but what clips do i need for this, there appears to be a small hole in the wheel arch liner that i assume connects the trims together? it just keeps popping out.
  8. Think that side bit is common , many people screw them from inside or cable tie. Like where the bumper meets the panel
  9. Cal
    Cal
    Yeah the side one is common.
    Two screws will sort it out..
  10. a mate managed to use some speed clips or something he said and it hasnt moved since.
