Hi just after some advice. Are the brakes on a 225 sport same as a 225 cup as in size ect rear bearing internal diameter size. Just my brakes ate shot on my cup but been offered some off a 225 sport.. Any help would be great.
No the cup r26 and f1 are the same 225 sport are smaller I learnt the hard way and they are plan not drilled the bearings are much larger and will not fit hope this helps
Then yours should be the larger bearing but check the part number embossed onto the rear hub before you buy I have a used set if your on a tight budget that o bought for my sport but they are the larger bearing that you'll need but check as it can be mare renault said mine were the larger type but not lol
Check your rear centre nut. 30mm nut is 25mm bearing and 36mm nut is 30 mm bearing Iirc. My 225 trophy has a 30mm nut.
I've just checked my nut size and it's 30mm so must be 25mm besting internal diameter is that correct
