Hi lads devasted! I have drove into a cone at work that I just didn't see!!! The bottom splitter has cracked and come off! Does anyone know where to get one / what price are they? Not the F1 type blade the bottom pierce of plastic! Many thanks Elliott
http://www.renaultpartsdirect.co.uk/product/renault-megane-250-bumper-splitter/ I think this is what your after.
How do I remove this lads I'm attempting now and can't figure it out! Took the 7 10mm nuts off but something else must be fixed?
confusion, the part you describe and the part mentioned are not same, if you've removed bolts then its not the two little riveted blades in front of wheels you could be referring to under cover or the front aerodynamic splitter. if its the front splitter need to remove whole front bumper to detach the splitter
Yes it's the bottom splitter not Underneath the car but the plastic lip that is at the bottom front....so it's bumper off? Any ideas how?
If only i thought of that. I've sorted it now. No bumper off job....just 7 10mm bolts off then cut two rivets off and done
