Black R26 £4500
Discussion in 'Cars For Sale' started by Waltz172, Mar 5, 2021.
  1. For sale is my R26. Change of job means the Megane is for sale. I've owned the car for over 2 years.
    Mileage: 132k
    MOT until September
    During my ownership it has had:
    Belts and water pump done @awmotorworks
    Rear callipers
    Handbrake cables
    NGK plugs
    Inner rack joints
    New genuine xenon headlight units and bulbs
    Reconnect faulty earths
    Radiator
    AC condenser
    Dot 4 brake fluid
    N/S driveshaft
    Brembo front pads
    Full services at Mark Fish Motor Sport, as well as a thorough going over
    I bought the car from a member on here and he carried out the following works whilst he had it:
    Engine:
    RS Tuning map - 278hp / 302ft/lb capped torque
    Properfec recirculation valve with uprated spring
    ITG Induction Kit
    Forge Front mount Alloy Intercooler
    Forge Hard Pipes
    3" RS Tuning Decat
    KTEC 3" Exhaust with Magnaflow 3 inch Sportcat, MOT friendly
    New standard engine and gearbox mounts with Powerflex insert on the lower Dogbone mount
    630cc Injectors
    250/265/275 Turbo
    Transmission:
    Standard LSD
    TTV Single Mass Flywheel
    R26r Clutch
    Slave Cylinder + Fluid
    New O/S driveshaft
    Short Shift mod
    Interior / Exterior:
    New Style Renault Badge
    White LED Bulbs
    Pioneer component speakers
    Sony head unit with Bluetooth connectivity for streaming and handsfree phone.
    Steering/Suspension:
    Genuine R26 replacement shocks
    Cooksport springs.
    Replaced suspension strut top mounts
    New Drop Links (OEM TRW)
    New Anti Twist Link (OEM TRW)
    New Inner Tie rods (OEM TRW)
    Trackfocus Direct inner steering bush
    Wishbones fitted with new TRW bottom ball joints, front and rear bushes
    Brakes:
    Brembo HC front discs
    197 Rear Discs
    PBS Prorace Rear Pads
    Braided lines
    Stainless Steel Brake Pin Kit
    Bad points:
    Given its age there's the odd minor scratch and dent, nothing major
    Wheels in need of a refurb as paint flaking
    The standard wear on the driver's seat bolster
    Rear pads and disks will need doing in the next few thousand miles
    It's currently on Uniroyal 3's. The rears have got plenty of tread, the fronts will need doing soon
    I also have a set of AD08R's and again the rears are like new but the fronts only a couple mm left on them.
    The car is in Colchester
    Pics to follow
    a couple of old pictures
    more to follow
  3. IMG_5836 - Copy.JPG IMG_5845.JPG IMG_5846.JPG IMG_5847.JPG IMG_5848.JPG IMG_5849.JPG IMG_5834.JPG IMG_5842.JPG IMG_5844.JPG
  4. Reduced to £5300
  5. Reduced to £4800
  6. Reduced to £4500
  7. Pm sent
  8. The car is still for sale
    I’m open for sensible offers now as I could do with it being gone
    I know it has high mileage but mechanically it’s very good,
    I think it’s worth a lot more than what I’m selling it for and I can’t believe I’m selling it for so little.
  9. a few more pictures
  10. If you want a quick hassle free sale, drop me a pm. Thanks!
  11. Is this Still for Sale?
  12. Sold
