Anybody fitted d2/ksport big brake kits to a mk2. Any problems with discs warping/overheating. Getting sick of changing discs after every track day.
Don’t know anyone who’s done this Horg, usual route is to go for mk3 discs and callipers as a very effective upgrade. Not sure what discs you're running, mate uses Brembo high carbon plain discs on his track r26 and they do an entire season with no issues.
Been through 3 sets of brembo high carbon discs and now a set of floating discs with ally bells. Running winmax W3 pads and removed the fog lights and put ducting in for some cold air car brakes brilliant it just cooks both discs after about 4laps of hard braking
Hi Horg My Brembos are into their 2nd season and apart from surface cracks are still okay, Standard Calipers and DS1.11s
Exactly the setup my mates car uses with no ducting and has no problems, perhaps try a change of pad horg, or go mk3 setup.
Do you have to run rs250 discs with 250 callipers, I’ve looked at that many options it’s blown my mind!!!
OMG what are you doing with your brakes, do you do cool down laps, do you bed them in when new, the only other thing is pad build up on the disc's, that's when you stop and the pads deposit material on the discs. That was the only problem i had, but driving and braking on the road sorted it out. I had the mk3 setup on my mk2, no air ducting, ran loads of different pads, Performance friction Z rated were great, but they don't work on my 265, i ran Carbon Lorraine 8's and they were way too much for me, these are the ones i now use on the mk3 and there okay, nowhere near the stopping power of the mk2. I know a couple of guys that have run Winmax on there mk2's, but they were the 5's i'm sure, i have not used them so don't know what there like, although i have driven one of the cars on track (mk2 with mk3 brakes) and they seamed pretty good.
I have done at least 8-10 trackdays on the same disc's maybe 2 sets of pads on my mk3, i'm really heavy on my brakes. I could make back up quite some distance on faster cars in the braking area, I was told by an instructor to brake hard into a corner as late as you dare, if you brake too much then let off, better than gentle into a corner and pressing harder and harder to slow it down, the second one builds up a lot of heat.
I’ve all ways bedded pads in and always run cool down laps, the brakes start juddering quite harsh after 3-4laps of hard driving. I was hoping the standard brakes with uprated pads would be up to the job. I’ve checked all the pistons, made sure the pads are free. I ran winmax w5 and dropped down to w3 in the hope it would stop the brakes Getting so hot but no luck. Where is the best place to source callipers and discs from rs250s?
Sorry mate, it has to be your driving style then, i do a lot of trackdays and i don't think i have ever had disc's warp that bad that i needed to change the discs. All i ever ran was HC Brembo discs and a variety of pads, some were better than others. The discs are easy Ebay etc my local parts supplier does me a good deal as well, they need to be drilled or slotted as the holes are 114.3, mk2's are 108. You need longer bolts and some adaptor plates making, calipers you can get new, used or from a scrapyard/breakers. I did a thread on here a long time ago
Some disc and pad combinations never seem friendly whereas others are perfect, like RichK’s suggestion. Sometimes not being an aggressive braker means you’re spending more total time on the brakes and therefore less total time off the brakes leading disc warp.
I was told the same, so I changed my driving style and brake fade delayed at least a few laps. firstly i concentrated on finding the latest brake points at the end of the long straights and it helped significantly.
i was also told by local AP Racing dealer, the longer you hold your brake the more heat it generates than you slam it very hard but short.
I had pad pick up in my early days, shuddering when you brake, but now, I brake as late as I can, get on, get off the brakes, no lingering, and do not now have any problems. I run DS 1.11, they have ruined the wheels, but they do stop.
I’ll get Blyton booked and alter my braking style, I’ve always braked a little earlier to keep it smooth and not upset the balance of the car.
Have you ever checked the inner steering track rods and tie rod ends on both sides?. I had problems in the past with those, changed them, problems sorted when heavy braking
Thanks for everyone’s suggestions, I changed pads from winmax to ferodo ds1.11 And what a difference! No mor brake judders or wobbles. Tried and tested at blyton yesterday. It must have been pad pick up on the discs?
The floating discs I put on were grooved and didn’t help. Got to have been the winmax pads just picking up, the obviously don’t like renaults
