Autohaus Kirfel set up
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by r_turner01, May 30, 2023.
  1. Just another positive suggestion for anyone needing work on their Megane in Adenau.
    Friend suggested to use them and went along to book my car in, got in within a few weeks, turned up and Tim did a basic check over and called me with a couple of suggestions for the car before corner weighting and setting up, which i went for, he had all the parts in stock and was done in just a few hours with new springs and shims, corner weighted, car is 1320kg i discovered, full alignment and headed off to do some laps and WOW what a difference, the car inspired so much more confidence in the corners, could really lean on it where as before its never quite been there! As a side note, I also installed Endless ME20 pads and between the stopping power, the AR-1s and the new set up the car is finally performing how it should, very noisy pads, rock stiff suspension, massive amount of heat inside the car, and a generally miserable experience on a hot day.... I LOVE IT! :smiley:
    GT4Zed likes this.
