ABS/ESP Problem
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by harryg, Nov 5, 2014.
  1. Hi guys,
    Recently my cars developed an abs/esp problem. Under braking at low speed there is a judder coming through the pedal and it is throwing up the abs/esp lights. Has anyone experienced this before?
    Thanks Harry
  2. It will most likely be your abs sensor needs replacing. Ideally get it on a Renault clip diagnostic to find out which one needs replacing. There not particularly expensive or difficult to fit either mate.
  3. I had this exact problem 2 months ago mate, was juddering at low speed braking. Mine was passenger side abs sensor.
    £44 for the sensor from Renault then fitting on top.
  4. Mine does exactly this! I was dreading how much it would cost from Renault but that's fine if it fixes it!
  5. MicKPM
    MicKPM RSM Trader RSM Trader
    As above, it's not a tricky or overly pricey job... which is rare on a Renault. You just need to find out exactly which wheel is causing the false flag
