265 door not unlocking with key
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Veloce, Oct 24, 2019.
  1. Hi all,
    I have a 265, and the car won’t unlock when using the emergency key in the fob (both original and spare key).
    The keyless entry and button on the remote work fine.
    I pulled the door card off today, and can see the barrel spinning as I turn the key.
    Has anyone else encountered this? I’d also be curious to know if the emergency unlock is fully mechanical or electric...
    Cheers,
    Luke
  2. Are you sure you were doing it right , I thought my passenger side would not unlock, but did get it after playing about with it
  3. I think so... Put key in door, twist key, pull handle. Is there some sort of trick?
    Also my car doesn’t have a barrel on the passenger door, only driver side.
