250 Standard recirv valve
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by james157, Dec 15, 2014.
  1. I'm going to fit a 250 turbo onto my Trophy.
    I've had enough of the noise ftom the hks bov and want a recirv valve instead.
    Is the standard one upto the job or will I need to fit a forge one?
  2. Standard should be fine. What mods have you got?
  3. 3" scorpion decat, 3" ktec exhaust, Ktec 60mm fmic, forge hard pipe kit, actuator and silicone inlet pipe. Modified airbox with K+N panel filter.
    Just got some 630s so will fit them just before the map.
  4. I'll swap over the Forge actuator sering as I've already got it. I will leave the standard recirc on then.
    Thanks fellas.
