2011 Clio 200 - Racing blue- Recaros & Cup chassis
Discussion in 'Cars For Sale' started by hsustyle, Mar 7, 2026.
  1. 2011 Renault Clio 200 Renaultsport MK3
    More pics here-
    https://www.dropbox.com/scl/fo/xmh6...ey=bmhcdtw8mvdpzzg86rjj3g3en&st=cz5m3awq&dl=0
    Cup packed car
    Registered 16/07/2011
    Just over 95,000 miles
    Hpi clear
    2 previous owners
    MOT expires 12 November 2026
    Desirable Racing Blue with satin black Speedline wheels. Very clean example inside and out. Properly looked after car with thousands spent on preventative maintenance. Maintained regardless of cost, not run on a budget.
    Two fully working keys
    Full service history
    All original booklets present
    Huge folder of receipts
    Recent work in the last 4 weeks
    Clutch damper delete fitted
    Clutch bled
    New gearbox oil
    Rear N/S TRW brake caliper
    Rear Brembo brake pads
    Brembo front discs and pads
    4x Michelin Pilot Sport 5 tyres
    Upper torque mount
    Lower gearbox mount
    Lower engine mount
    Inner and outer track rod ends
    Pipercross panel filter
    Stock OEM centre silencer refitted
    Last week
    Machine polish
    Ceramic coating
    Maintenance and major work
    Cambelt done July 2025
    New clutch July 2025
    New K Tec lightened flywheel July 2025
    Gearbox rebuild carried out by K Tec July 2025
    Gearbox rebuild included 3rd and 4th synchros
    Dampers and hubs replaced within the last two years
    Water pump
    Aux belt and tensioner
    Sump gasket and rear main seal
    Major service
    K Tec Racing specialist invoice for all major work
    Spec
    Cup pack
    Mint Recaro yellow dot seats
    Bluetooth calls and media connectivity
    Keyless start
    Auto lights
    Auto wipers
    Climate control
    Fully loaded example
    Drives tight, sharp and exactly how a good Clio 200 should.
    Included with the car
    Upgraded Clio 197 / 200 engine mounts with Powerflex inserts included. This is a popular upgrade that sharpens the driving feel and reduces engine movement. Includes upper engine mount, torque mount and gearbox mount. Too much vibration for my liking.
    Bad bits
    Tiny occasional & intermittent crunch( more like a click) into third gear. Most probably wouldn't even notice.
    Small rust scab on rear bootlid, see photo
    Front bumper and lower bonnet grille slightly faded
    Small scratch on the lower bonnet grille, see photo
    Tiny (2mm) chip on lower area of windscreen, passenger side
    I bought the car to teach my partner to drive. The lightened flywheel makes the car more sensitive on pull away which does not make it ideal as a learner car. Because of that this will need to go and we will move to a Mk2 Clio instead.
    Price £8,600 ono
    Location Tunbridge Wells
    07988377966
    PX considered for a really clean, rust free and close to standard Phase 1 or ph2 Clio- 172 Cup or 172 with cruise control (silver, black, red) or a full fat 182 or Trophy (silver, black gold, red). Can put cash either way.
    No time wasters.
  2. Now £7500
  3. £6800
  4. Sold
    NotaDiesel!!! likes this.
