11' Megane 3 RS (ABS fault)
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Angus Wong, Apr 25, 2017.
  1. Hi all,
    Last weekend, I inserted the card key before start the engine, Red warning brake fault occur, abs, esp. 2 fault code per below:
    DTC 505004 ABS
    DTC 401001 ABS
    Technician told me that I need to replace the ABS module, any idea/advice? Thanks.
    Noted that I do not upgrade/maintenance any brake parts in Apr, I already checked the below, all look fine: Brake fluid level, fuse #12 5A, ABS sensor and I already replace new battery.
    Last question, it is necessary to re-program/re-map if I plan to replace a 2nd hand ABS module?
  2. Have you checked the large 80 or so amp fuse on the pos+ terminal of the battery?
    Sent from my FRD-L09 using Tapatalk
  3. Hey, sorry, not really understand.
    Any photo for reference? Please.
  4. Cannot find the fuse large 80. :worried:
  5. I had a similar issue, where the ABS light came on etc.
    Mine turned out to be a faulty speed sensor.
  6. Fault code is?
    Seems not DTC 505004, 401001 ABS?
  7. ¿podrían resolverlo? Yo tengo el mismo error
  8. [QUOTE = "Angus Wong, publicación: 153163, miembro: 12015"] El código de falla es?
    ¿No parece DTC 505004, 401001 ABS? [/ QUOTE]
    Yo tengo esos codigos y no puedo solucionarlo.
  9. Hello,
    I have the same dtcs in my megane 3, have you solved the problem?
