R26 Abs sensor
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Just-that-ek, Mar 26, 2019.
  1. Does anyone have a how to guide on how to change the abs sensor?
    How easy is it and what tools are needed?
  2. Quite easy to do but the access does not make it easy, a small flat blade screwdriver is needed to gently lift the retainer clip and gently pull, replacing just push in.
  3. I bought an aftermarket sensor to find it too short. Bought a genuine one from RPD which was fine. As said, just a small bladed screw driver to lift the connector tab at the hub and it pulls out. Just a connector at each end to undo really.
