225 Wishbone front bolt removal
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by iiPaul, Dec 13, 2016.
  1. Hello,
    Cut a long story short I need to replace my lower ball joint on my 225, the old one is out I just need to press the new one in, I've got the rear bolt out I just need to remove the horizontal bolt..
    How do I do this, do I need to drop the subframe? If so what bolts need removing in order to get enough clearance to get the bolt out?
    Thanks Paul
  2. You need to drop the front subframe
  3. How many bolts are needed to undo to drop it?
  4. Nice one mate cheers [emoji1303]
