Wipers
Discussion in 'Exterior & Bodywork' started by NotaDiesel!!!, Oct 28, 2018.
  1. Every car I have had when I come to wash(or scrape the window) I lift the wiper clear of the screen.
    Am I missing something?
    I can lift it about 5mm before it hits the inner edge of the bonnet.
  2. Yup, get used to it :tongueout:
  3. thanks.
  4. Push the wiper stalk behind the steering wheel all the way down. It then moves the wipers vertical so you can lift them all the way off the screen without them hitting the bonnet.
  5. Is that an actual setting? Does it hold at that point or do you need to turn of the engine at this point?
  6. While the engine is off, push the stalk all the way down and it holds the wipers in the vertical position.
    Sent from my SM-G950F using Tapatalk
    FatRS likes this.
  7. I assumed thereā€™d be something like that. Seen it on other brands but assumed it was normal naff Renault.
  8. Used it today. Amazing.
