250 Tapping on cold start
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Charlie Howard, Jul 21, 2018.
  1. Charlie Howard
    Only on cold starts and goes way after 30 seconds I'd say. Get a tapping sound. I've heard it's due to oil from other posts but I use Petronas 5W-40 3000 AV, should I change to something like Castrol Edge or Shell Ultra? Is this doing any damage?
    Sent from my ONEPLUS A5000 using Tapatalk
  2. Dephaser on the way out
  3. Charlie Howard
    What's the dephaser?
  4. It's expensive if it goes wrong :tongueout:, will need cam belt change ect
  5. Charlie Howard
    Oh well the cars only done 37k miles and had it changed at 24k so I don't think it's that? Been doing it for months.
    I've heard it's tappets or oil?
  6. Do you have a receipt for it being done, it normally only gets changed if you request it
  7. Charlie Howard
    Yeah have the receipt, owner was very anal about stuff and kept on top of stuff.
    Doesn't Jamie have knowledge of this?
  8. Charlie Howard
    Just double checked, 2016/24k miles it was changed and on 37k now.
  9. Change the oil for some Titan race pro s with Ester properties. That will sort your cold tapping.
  10. Charlie Howard
    Is the tapping doing any damage? Because if not I'll wait for 6 months when my change is due, oil is pretty new.
  11. -Jamie-
    Dephaser solenoid, Try changing that first. Few have had this issue and changing the solenoid sorts it.
    Its located next to Cyl 1 coilpack.
  12. Charlie Howard
    Ooo that's quite expensive, I'll give it a go next month.
    So any damage being done so you think or just an annoyance.
  13. -Jamie-
    Its not that expensive lol.
    Its just noisy, Id imagine it would eventually kill something though
  14. Charlie Howard
    Not overly expensive but more than I'd thought, I'll give it a go. So you reckon something like Castrol or Shell would be better than Petronas? I thought I picked a good oil as that's what KTec suggest.
  15. I am on shell helix, it is renault spec and have no problems
  16. Charlie Howard
    Might try that first as it's cheaper then if not I'll go Race
  17. -Jamie-
    Renault spec Elf oil is more than upto the job and is cheap as well.
  18. Charlie Howard
    Might have a look at that then, I'll try oil first then I'll change that sensor.
  19. Charlie Howard
  20. Gavin.
    Gavin. RSM Admin
    Mine taps on cold start, it had a new dephaser in December too. oIt goes when it's warm so doesn't worry me much
  21. Charlie Howard
    I just worry after my 225 blew up with what seemed like a small issue.
    I'll try oil but me and my mate checked over it all today and he told me don't worry it's fine even if it is the tappets which it probably is.
  22. Charlie Howard
    Is that oil definitely correct before I buy it? Seems there are slightly different variants of it.
  23. Yeah it's 5/40 all good
  24. Charlie Howard
    Cool will go for it.
  25. The solenoid can be had for a lot cheaper then Renault charge. Google Search pn:
    8200642783
    A quick search shows it’s a Delphi unit and it’s about £50
  26. Just go race mate. The shell stuff is just standard oil. You need ester oil.
  27. Charlie Howard
    Is the Delphi unit any good though?
  28. The original one in your car is a Delphi I believe
  29. Charlie Howard
    Oh didn't know that, thanks!
  30. Charlie Howard
    You for a link? I can't find any under 80
  31. Charlie Howard
    So before I get one, is the thing next to coil 1 held in by the same bolt?
  32. Renault disagree with you, but what do they know
  33. Charlie Howard
    Yeah seems like conflicting opinions here, some say the more expensive ester oil is better whereas some say just use what Renault say. Not sure.
    Anyway, is this the part?
  34. Renault spec oil is completely safe and cheap. You don't need the race oil. Only time I'd get race oil is if the car was on track a lot, in which case it will work better than standard. Shell helix or Elf (fully synth) is completely okay. I personally use Shell Helix but both are approved and will cause no issues providing you don't initially overfill like I did
  35. Charlie Howard
    What's the issue with Petronas then? It's fully synthetic and 5W-40, not like it's a cheap oil. Just seems like Shell/Castrol/Elf will be the same.
  36. To my knowledge, yes they should work pretty much the same as long as viscosity etc are the same. Not sure if the better brands put in less additives or more, which would explain the differences (if any). Personally I'd always go with manufacturers recommended ones as they know more about the engine than we do (so Shell or Elf), unless it was a dedicated track car where it would be better to change.
  37. Charlie Howard
    Hmm okay well worth a try.
    Is that the correct part in the photo above anyone?
  38. Yes the part above is the dephaser solenoid. The standard oil is perfectly fine, but the race oil will help better with the cold tap
  39. Charlie Howard
    Okay thanks mate
