Scangauge AFR
Discussion in 'Technology Chat' started by Korky, Jul 13, 2016.
  1. Has anyone managed to add AFR to a scangauge, i am unsure of what lambda protcol the megane uses.
    Regards
    KT
  2. Carn't read afr on scangauge i dont think
  3. Besides, the Megane only uses narrowband
  4. I found this post
    Agreed the Megane is only narrow band but should give a general indication, if it was for tuning I'd Go aem and lc-1 wideband setup but i just think it would be good to get it working with the scan gauge as an additional function.
    Regards
    KT
  5. TimR26
    Here is my solution to the problem...
    Korky likes this.
  6. Tim, I have a picture of yours saved, did you have an extra boss welded into your downpipe for the wideband?
    Regards
    KT
  7. TimR26
    Hi, no the wideband sensor screws into the hole for second lambda.
