RS 250 Megane- road legal track car. 321bhp/360ftlb. Very special car,top Spec Cup.£12,500.
Discussion in 'Cars For Sale' started by Scott Bradley, Oct 24, 2017.
  1. For sale my RS 250 Megane Cup sport.
    In a nutshell I bought this from Dale Groves off here a couple of months ago with a view to have some fun trackdays. Unfortunately for me having 3 years off trackdays in big powered Audi’s, I didn’t realise how much my eyesight and reactions have deteriorated lol.
    I have only done 1 trackday at Cadwell recently where it performed impeccably and drove home without missing a heartbeat!
    For the above reason I know my skills/experience are not matched for this car, so I am offering for sale.
    This little RS runs rings around most cars on track and road with the right tyres.
    It reacts very sharply and effortlessly gains pace with its 360ftlb torque.
    I’ve spent £1100 on brand new ds1.11 pads and oe rs275 non slotted discs. Full service including ALL fluids. Full geometry setup and full front Brembo overhaul.
    Full service history right up to date with all stamps in service book.
    Car really is special to drive and is so well setup it’s chassis is just sublime!
    Car is really in great shape with just the normal very mild stone chips to front end as to be expected.
    Mileage has just turned 101k but honestly, genuinely feels like sub 50k!
    The mapping (RS Tuning) has only been carried out within the last 6k miles so it’s ran an easy life.
    Spec below, (cut and pasted from Dale’s original ad)
    Powerflex engine mount insert
    Vibratecnics lower pendulum mount
    275 gearbox mount with M12 bolt upgrade
    Rstuning live map 321hp/360lbft very lively indeed.
    LSD + sport button.
    Colder range NGK plugs
    Bosch upgrade ignition coils
    Airtec version 2 intercooler
    Airtec turbo cooler/secondary radiator
    HEL Thermostatic 80deg oil sandwich plate
    Heat exchanger delete with coolant pipe bypass
    19 row oil cooler mounted inside wheel arch
    Gold reflective wrapped boost pipes
    Ktec intake with heatshield
    MTC intake pipe
    Pro perfekt recirc valve with upgraded spring
    Scorpion 3" Decat
    Ktec 3" non-res cat-back
    Satin black engine cover
    Rstuning map 321hp/360lbft
    KW Clubsports (£2500) set at recommended nurburgring bump/rebound/height settings -2 degrees front camber
    Scuttle and turrets modified for on car access and adjustment
    New front wheel bearings
    New bottom steering joints
    OE non slotted RS 275 discs
    HEL braided lines
    Ferrodo ds1.11 front pads
    Rc5+ rear pads
    Hi temp brake fluid
    The car will come with 2 sets of Enkei rp01 wheels in a quite rare 17x9 et42 fitment. Yes, 2 sets (8 wheels)
    Set 1 satin black
    Front 255/40 ns2r 120 soft (track) compound
    Rear 235/45 ns2r 120 (track) soft compound
    Staggered "nurburgring" setup
    Set 2 anthracite
    235/45 all round toyo t1r
    Projector headlights with 5k HIDs
    Satin black badges
    Gloss white sunstrip
    Shortened front plate
    Rhino lip(removed but still have it)
    Debadged rear
    Wiper delete with glass blanking plug
    Satin black exhaust surround
    Stubby aeriel
    Wheel arch/front bumper modified for air flow to oil cooler
    Genuine 275 trophy alcantara steering wheel
    Rear seats removed
    Custom rear carpet and false floor
    2 x Corbeau clubsport XL on custom mounts/OE runners
    Car runs faultlessly on both road and track, doesn't use a drop of oil even with strong use thanks to the oil cooler. The oil has been changed every couple of months with genuine Renault parts and will continue to for as long as I own it.
    The cooling system upgrades have been carried out to ensure the car does not suffer the temperature management issues some 250's experience on hot track days. The A/C is still intact and works perfectly
    Regards
    Scott
    Feel free to call to discuss anything further 07815 195013
