Roll centre adjustment kit
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by CUP270, Oct 10, 2018.
  1. Anyone know much about roll centre adjustment kits ? - are they available for the Megane 3?
    I see they are available for the Clio.
    Anyone had any experience with them, even on cars other than an RS ? - WRX owners perhaps.
  2. I used them on my EP3 Type R - and a few friends did
    But they were lowered on coilovers quite a bit
    They do seem to work quite well
    I'm not sure how badly the Megane is affected, since I lowered mine I've not really looked at the angle of the lower arm, and they have that fancy hub setup... so not sure
  3. Thanks for the reply - my car is on height adjustable BC Racing coilovers - see pic, guard is 609 mm from the ground. Its about 30 mm lower than stock, I need to check on a standard car.
    I don't have any handling problems with the car, just looking to see if any gains can be made without going to stiffer springs or putting nolathane bushings in the lower control arms - they just make the car to brittle on the road.
