R26 Project (#1581)
Discussion in 'Megane Projects' started by SomeGuy, Jul 4, 2018.
  1. Hello all,
    Recently acquired the above in Deep Black to replace my trusty Clio 182.
    I figured I should pop a thread up here rather than clog up the suspension related thread I have started previously with unrelated info & cries for help.
    I had assumed given the mileage (126k) that it would be a little tired & in need of a refresh, but the immediate requirements were somewhat more urgent, and expensive, than I had planned for.
    Previous owner, in fairness, did take pretty good care of the car but mostly through corrective maintenance rather than any refreshing of tired components, so lots to get on with which I shall detail in the following posts.
  2. So, first course of action was to pop to my friendly & knowledgeable local RS specialists predominantly for the belts to be changed (overdue) but also for a healthcheck to be performed.
    The list was rather more considerable than I had hoped as I alluded to in my initial post above & includes issues with the inner CV boots, suspension (rear shocks & springs), tyres (all four), mounts & a few other bits & pieces.
    The car is also in need of a good clean inside & out & has a few cosmetic bits to sort such as the driver seat bolster, engine cover, undertray & front bumper reattached correctly (not flush).
    So, as stated, lots to do!
  3. First new parts day today.
    Order placed for the bits that need to be addressed due to expiry/condition:
    Inner CV boots
    Gearbox oil & sump washer
    Shocks (front & rear)
    Shock Nut & Bolt
    ARB Drop Links
    Anti-Twist/Rotation Links
    Centre exhaust mount/bracket
    Cooksport springs
    Hub swivel bearings
    Hub swivel bearing seals
    Ouch. Still, at least it will be done. Track rod ends, & possible inner track rods, were done not too long ago so I'm hopeful that these will be ok. Also hoping that the bushes, control arms & balljoints will also be ok for now, although knowing my luck they'll probably need to be done too.
    Will be fitting it all over the next few days, so should be an 'in at the deep' end introduction to the R26, mechanically speaking.
    Next outlay will be Michelin PS4 x4 fitted & geometry/alignment done, which I will do once the suspension refresh has been completed.
  4. Further to this, I now have the good ol' 'check injection' message, complete with limp mode, ongoing & it would appear that the A/C is unhappy about being asked to function on anything other than 'molten' for an extended period of time.
    I'll check the usual 'easy outs' for the check injection message (sensors, hoses) & i'll also be picking up an OBD reader to see if any codes have been thrown up that will lead me to the cause of this.
    The A/C appears to cool on it's lowest setting for a period of time, although not particularly chilly. But seems to give up & blow hot air instead after being on for a while. Hopefully this is a re-gas scenario, but I'll check the rad pipe connection & pressure switch.
    Lot's to read, for which you have my apologies. Should now be an occasional update rather than essays galore.
  5. Sounds like you're having quite a bit to do! Doing some of the work yourself?
    Throw up some pictures!
  6. Yeah, plenty to do! Yup, doing it all myself (famous last words).
  7. Good luck! Once you get to know these cars, they are not that difficult to work on. It takes me 5 minutes these days to removed front bumper and undertray!
    Have you managed to align your bumper yet? They quite a PITA to get right. Main issues I've detected are:
    1. The headlight unit has a broken bracket (thus bumper pulls headlight down and causes misalignment).
    2. Undertray(s) removed by previous owners. This is not as major but it help make the whole bumper rigid and when secured with the bolts at the subframe, prevents bumper from sagging.
    3. The bumper is not correctly clipped into the headlight. It must clip in a specific way or it will be crooked. Just look in there and you'll see how the two should go together.
    4. The little "ear" through which the torx bolt goes where the wing and bumper meets, needs to be pulled over the spire clip and then the "ear" bolted down between the wing and spire clip.
    These have been my finding to the issue and have them currently aligned quite well but definitely need new spire clips to replace the worn ones.
    Will hopefully be doing balljoints, tie rods, inner tie rods, subframe bushes and Powerflex control arm bushes this Saturday!
    Will take a few snaps and post it on my project thread.
    SomeGuy likes this.
  8. What brand of shocks are you planning to order?
  9. I've gone with OEM all round. It is my understanding that the Cooksports work pretty well with the damping so I didn't feel the need to further confuse things by adding aftermarket shocks into the equation as well.
  10. I wonder if Bilstein Shocks are compatible with this model.
  11. I believe there are some compatible Bilstein's (B14's?), but felt it would introduce to many variables that weren't matched.
    I'd have gone for OEM springs as well had they not been absurdly priced when compared with aftermarket options.
  12. Anyone know which bolts I need to secure the front bumper to the front inner wheel arch lining?
    I have 1 missing, 1 rounded, 1 correct & 1 'random' bolt in place. Somebody has clearly 'cowboyed' the refitting of the bumper which is reflected in the siting of the bumper at present, which appears to be an inch or so forward of where it should sit....
  13. should be 1 push in plastic fixing,
    and 2 torx screws,with plastic insert clasps, attached to the bodywork/bumper
    ,to screw the torx screw into.
    The bumper really is held on poorly..the majority of the fixing is the sprung plastic clips under the headlights...which snap for a passtime!
  14. here
    or not...stupid upload!
  15. Ah. More complicated than I had hoped. A link to the necessary kit/parts would be most appreciated.
  16. you might be able to get a` bumper fixings pack` from renault..going in to the parts dept next couple of days..will ask.
  17. but really its all standard stuff.,..the plastic push in fittings,i have just bought similar from ebay,and the torx scresw are nothing out the unusual..just a standard screw with a torx head,in the usual french style.
    the main bit is,if your under light sprung plastic fixings are still intact..this is the most secure fixing,as well as the undertray central part being intact...it keeps the bumpers shape.
  18. Further investigation today has confirmed that this is an option, part number 620102576S. Not cheap though!
  19. I haven't removed the bumper yet as I fear it won't go back on with it's current mishmash of random fixings...
    The bumper is sitting forward (gap to bonnet is too wide) & is not sat flush with the headlights, again, slightly forward of where it looks like it should sit.
  20. nothing is for the front of the R26..front lower grill£150..front bumper,bare without undertray..£330...central undertray £120..lower lip £60+..
    Is your undertray intact..most are not.
  21. releasing the bumper from the sprung plastic fixings under the lights is a delicate affair.
    they snap for a passtime..so be carefull
  22. So, ran out of fuel on the way home last night, which was fun. Fuel gauge suggested I had just under half a tank left, which remained the case even after I had brimmed it.....
    This leads me to assume that the 'float' in the fuel tank is faulty/broken/AWOL/other. Do I need a new fuel pump? Is this likely to be a contributor to the 'jolly' check injection message I have been getting?
