Power
Discussion in 'Megane Discussion' started by Zs_phil, Jan 27, 2014.
  1. so for the megane 250 what else?
    Filter
    exhaust
    decat
    intercooler
    remap.
    Are these needed forge actuator ,injectors,manifold
    :wink:
  2. -Jamie-
    First lot will be you for stage 2, 330bhp max, No need for Injectors etc unless your going Hybrid/bigger turbo.
    RST are doing a hybrid turbo now thats good for 350-360bhp and about 380ftlbs
  3. Cheers Jamie knew you'd know :wink:
    so with the hybrid from rstuning I'd need injectors
  4. That on standard internals Jamie ?
  5. -Jamie-
    Yeah, Stock tubby and injectors run out around 330bhp ish
    Jonny, Yep that is stock internals, Could probably pushed it a little more but then you run the risk of bending stuff internally, IIRC that was on 1.6bar on a Hybrid TD04
  6. Hmmmm, that's got me thinking a bit then. Do you know of any cars running that power on stock internals ? Any idea how much fitted from RST ?
  7. -Jamie-
    Yeah, RST's own 250 had the hybrid/Injectors/Decat/exhaust fitted a few weeks back
  8. -Jamie-
    Personally i would be getting a bigger FMIC as well, Should be able to keep the torque curve a little flatter
