MK3 Lower arm ball joints
Discussion in 'Car Parts For Sale' started by -Jamie-, Feb 19, 2017.
  1. -Jamie-
    For those looking for a cheaper solution and more sensible way to just replacing the full arm when your ball joint has gone i can supply the ball joints for £145 a pair. Also fit the Cli 197/200
    Mikeyjp likes this.
  2. Does the 197/200 use the same ball joint then?
  3. -Jamie-
    As far as i know, Yes.
  4. -Jamie-
    [​IMG][​IMG]
  5. Jamie, what tool are you meant to use to remove them? Is it a heat and chisel job or what?
    Sent from my FRD-L09 using Tapatalk
  6. Is this the bottom ball joint?
  7. -Jamie-
    Aye heat and a punch or chisel. I keep meaning to measure them up to see if I could get a copy spanner made up to size
  8. I'm thinking a machined c spanner........ [emoji57]
  9. -Jamie-
    That'a what I meant, not a copy spanner [emoji23]
  10. Hi Jamie, do you have any of these left?
    After a pair if still available.
    PM me details.
    Dave
  11. -Jamie-
    Yeah i do pal, Ill send you a PM
  12. I attempted to remove the ball joint with a chisel. Just would not budge.
    It ended up getting destroyed and there was no collar left to punch against.
    Heat did not help at all.
    I have since replaced the full arm from Renault.
    Has any one had any sucess?
  13. -Jamie-
    I've changed mine as have several others. There's a socket that fits them as well, IIRC it's for a laguna
  14. -Jamie-
    Anyone wanting some of these, doing an order this week, 140 a pair
  15. I thought these had to be pressed in/out?
    Or am I on about another ball joint?
  16. -Jamie-
    That will be the hub joints Chris
  17. Rgr. Which are the ones that Aarons autos, mark black et al change then?
  18. I’m tempted.
    So are they genuine Renault parts?
    I didn’t realise that they were threaded ball joints. So with that socket and enough heat and persuasion, they should come out nicely.
  19. -Jamie-
    Yup genuine joints, made by OCAP for Renault.
    Bit of heat and some persuasion is needed, mine came out with some of the above after 99k and several Scottish winters
  20. -Jamie-
    Yeah, I can also supply them at 60 quid for Upper and the same for the lowers IIRC
  21. Do you still have any of these for sale Jamie?
  22. -Jamie-
    The swivels? I sure do but ill need to check prices as they have all changed slightly due to the exchange rate
  23. A price for all 3 mate, as I'm tempted to just change all of them while I have it stripped down.
  24. -Jamie-
    That for both sides mate? May be able to do you a deal if your wanting all 3 for each side but ill get back to you tomorrow
  25. Yes mate. A deal sounds good
  26. -Jamie-
    PM sent.
  27. Just out of interest what would the cost for all 3 be for each side ?
  28. -Jamie-
    200 for each side Chris.
  29. -Jamie-
    £400 shipped to the UK for the full set of Swivel and lower arm joints d0a0c10a478a2a85128a8bdb1b456526.jpg
