Megane RS250 parts
Discussion in 'Car Parts For Sale' started by S4BiT, Feb 3, 2016.
  1. Steering column stalk kit £40
    ABS Pump/ECU £140
    Dual mass flywheel + clutch kit £300
    Electrical power steering column £120
    Right side door window motor £20
    Speedo with white needle £70
    Windscreen wiper motor £40
    Rear parking sensors x4 £50
    Tyre pressure sensors x3 £40
    Flywheel/clutch kit is in really good shape and low miles covered. Speedo have yellow counter and white speedo needle (some have red needle and its harder to see the speed on daylight). Tyre pressure sensors are about 2year old and there are no corrosion on them.
  2. hi mate,
    looking for headlight
    Height adjustment connector L+R
  3. I don't suppose you still have the rear (leather) seats do
  4. Only the rear bench and one headrest, if you are interested.
  5. Ok no problem. Have sourced a full set now anyway. Thanks for the reply
  6. Hi @S4BiT, do you have the intercooler to throttle body pipe including the fitting at the throttle body?
  7. Trying desperately to not equire about that recaro seat...!!!!
    Start small, do you have this dash piece?
  8. Yes, i think i have thay dash part, but for the LHD car.
    Sent from my SM-A300F using Tapatalk
  9. Sadly it was broken as i remember, but there are some parts left of it maybe?!
  10. Sadly it was broken as i remember, but there are some parts left of it maybe?!
    ewant81 likes this.
  11. If you have any of the parts at he throttle body end of the pipe it would be helpful. In particular if the portion of the pipe that bolts to the throttle body is intact.
  12. Bumpers? Rear axle?
    Pm me please
    Dan
  13. Do you have the centre consol piece that sits just in front of the gear lever? With the cup holder etc
  14. -Jamie-
    I do if he doesn't Lewis, mine centre console is lying in the workshop after fitting my CAE
  15. Lewis I left a whole console section at Ktec Friday, maybe ask if you can have that?
  16. Well that's why I'd need one. Thinking of a cae and want a spare centre bit so I can cut it as I don't want to start butchering the standard one in my trophy. I think it's literally just the surround to the gear lever isn't it rather than the entire price that pops out. What would you guys want for either one of yours?[emoji848]
  17. -Jamie-
    It's the whole upper section and bottom part of it that needs trimmed.
    I'm just gonna bin mine so call it 35 quid for the whole thing and that should cover postage if you want it
  18. I dont have that centre console anymore, throw it to trash.
  19. Have you got the Recaro subframes by any chance?
  20. Sorry but i dont have those.
  21. Ring Chester at Ktec just say Andy who had his car there Friday said you can have it. I left it there for them to bin at 5pm Friday, unless it went Saturday or this morning probably waiting to be skipped.
    What do I want, nothing, it's free. I didn't want it.
  22. Hi,
    Do you still have the full wing mirror cluster?
    Thanks,
    Dan.
  23. Hi,
    You mean the adjuster?
  24. No the whole mirror, including the part which attaches to the door.
  25. Sorry, but i dont have that.
  26. Passenger side lower door plastic still available?
  27. Dont have, sorry.
  28. Plastic engine cover ?
  29. No, sorry.
  30. Ok thanks anyway.
  31. I still have those parts:
    ABS Pump/ECU £140
    Rear (outer, yellow colored) parking sensors x2 £20
    Brand new Cup springs x4 £30
    Speedo have yellow counter and white speedo needle (some have red needle and its harder to see the speed on daylight). Have some other parts like sensors and plastics if needed also, for example OEM lambda sensors etc.
    You can make me an offer for the parts above also, as i don't see that I'm gonna need them myself and they are just sitting taking space. Maybe someone needs them :smile:
  32. Still have the parts above, maybe someone needs them?!
  33. You still got the springs?
  34. Yes, still got them.
  35. Would you post? If so any idea on cost?
  36. Did you sell the gearbox ????
  37. Gearbox sold
