Is the suspension on a ph2 non-cup different from a ph1 non cup?
Discussion in 'Megane Discussion' started by MrJP, Aug 6, 2013.
  1. As above, I've used lots of searches but keep finding the same info about cup vs non cup. It seems that the steering was improved for the ph2, but was the suspension on the non-cup left as it was pre facelift?
    Also, if you wanted to swap to cup suspension it seems that you need eibach springs and cup dampers to get the same level of handling to a cup car... can someone confirm or deny, have I got this right?
    Cheers, James
  2. Nobody?
  3. Non cup Ph1 -> Ph2 is the same for all intents and purposes. If you want to change to cup suspension then yes you'll need both the springs and the dampers.
  4. Thanks, just wanted to confirm my searches were fruitful.
    Cheers, James
