Hub swivel bearing.
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Ratboy0940, Mar 5, 2018.
  1. Evening,
    225 Cup not self catering. It looks like it's the hub swivel bearings. Can the bearings replaced or do I need a whole hub? If so any recommendations on who to use pls?
    Ta in advance
    Grippa
  2. Evening,
    Ta in advance
    Grippa
  3. You can replace them, there is a part number if you do a search
  4. Ah brilliant thanks!
  5. Stupid question time. I need two of these don't I? One top, one bottom? And they should come out with a press?
  6. matt e
    nah the top bearing is different to the to bottom bearing, you still need 2 bearings if your doing both sides
  7. Thanks again!!
    Only got the cup before new year with one of those dodgy MOT's for a year. Took it to my spanner man and it's gonna be about £600 ish to put it all right. Just had a set of cooksport springs fitted as 2 were snapped. I think this should be the end of it!!.............
  8. £600 for both sides i would say is strong money, 2 hrs a side max i would say
  9. I meant £600 ish to get all the niggles right on it before I look at any mods etc!
