Fan constantly on megane r26
Discussion in 'General Chat' started by aarroncolley, Nov 3, 2018.
  1. Need some help. Ever since buying my megane a month or two again the fan has been on and off but more on really. Replaced the thermostat and coolant temp sensor today bled all the system when run up to temp and it’s still not turned the fan off. It’s on from cold as well.
  2. Has the air con pump been removed ???
  3. Erm no it hasn’t mate
  4. Ahhh okay then, not sure what it is then, mine was running all the time when i deleted the air con.
  5. Been told it could be the air con pressure switch.
  6. If it does have air con delete how do I get rid of the problem ? Did you manage to sort yours out ?
  7. Hopefully all sorted mate replaced the air con pressure switch and the fan hasn’t cut in up to yet
  8. I got it turned off when i was getting it remapped
  9. Ohh that's good then, simple fix then
  10. Yeah and it’s now got a new thermostat and temp sensor just in case
