DF006 fault code
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Ashley, Nov 16, 2017.
  1. hey guys I’ve recently had the abs /esp light come on either after starting the car or a few mins into driving then it’s on constantly
    It seems like a bad connection as the dash lights flicker slightly before the esp/abs lights come on
    Fault code Df006 has come up on the scan saying front left hand wheel speed sensor open or short circuit
    I was wondering if anyone else has had a similar problem
  2. Removed the abs sensor last night and was slightly dirty also the magnetic strip on the hub had spots of dirt that I carefully removed
    No more lights and brakes work flawlessly again
  3. Yeah very common.
    Easy fix.
