Daily driver 2006 Megane F1
Discussion in 'Megane Projects' started by coetseejj.rd, Jun 25, 2018.
  1. Always getting confused when people start talking Cup, Trophy or whatever model but I guess mine is a Ph2 Cup?
    Had the car since 2014. bought with 133k on the clock. Now on 182k. Been an abosule pleasure to own.
    Unfortunately the years have taken their toll and I'm in teh process of renewing some suspension components as the budget allows.
    Here's a few pics of the changes I made shortly after buying the car.
    How I got it:
    The 2014 changes:
    76mm exhaust (*note, we do not have ready made aftermarket exhaust readily available in ZA, so the exhaust was built by a local exhaust place. How it looks really doesnt bother me at all.) :
    R26 rear spoiler (Fibreglass copy so was a pita to fit kindly centered):
    Prepping/cleaning off stock spoiler:
    DIY rear grill for custom exhaust:
    Old
    Making parts and mountings:
    Finished product:
    Brakes:
    Old
    New
    Some bay changes (Yeah the white heat shield is now brown lol):
    More to follow.....
    P.S. How can I insert aligned the full images not just the thumbs?
      File size:
      50.8 KB
      38
      File size:
      53.1 KB
      37
      File size:
      65.4 KB
      37
      File size:
      83 KB
      37
      File size:
      100.8 KB
      37
      File size:
      35.7 KB
      37
      File size:
      45 KB
      37
      File size:
      41.4 KB
      37
      File size:
      106.2 KB
      37
      File size:
      113 KB
      36
      File size:
      57.1 KB
      37
      File size:
      100.8 KB
      37
      File size:
      59.4 KB
      37
      File size:
      61.3 KB
      36
      File size:
      125.4 KB
      38
      File size:
      100.8 KB
      37
      File size:
      83 KB
      36
      File size:
      25.3 KB
      36
      File size:
      35.7 KB
      37
      File size:
      54 KB
      39
      File size:
      53.7 KB
      37
      File size:
      45 KB
      37
      File size:
      64.8 KB
      38
      File size:
      39.3 KB
      38
      File size:
      41.4 KB
      37
      File size:
      106.2 KB
      38
      File size:
      113 KB
      37
      File size:
      57.1 KB
      37
      File size:
      100.8 KB
      37
      File size:
      59.4 KB
      37
      File size:
      61.3 KB
      37
      File size:
      125.4 KB
      38
      File size:
      54.8 KB
      38
      File size:
      111.8 KB
      39
      File size:
      74.3 KB
      39
      File size:
      76 KB
      39
      File size:
      110.7 KB
      40
      File size:
      50.8 KB
      38
      File size:
      53.1 KB
      39
      File size:
      65.4 KB
      38
  2. Wow that is quite some miles on that megane.running well i take it.
    Lovely car
  3. matt e
    thats probley km not miles?
  4. Oops, yes KM not miles!
    Sent from my ANE-LX1 using Tapatalk
  5. Isnt that a F1?
  6. Yes it is. Is that like a separate variant to the cup and others?
  7. Yes..it was the one before the R26..and i think the rarest.
    Suspension was revised for this car..but it doesnt have the LSD of the R26.
  8. The lack of LSD I am aware of. My plate number is 1100.
  9. rare car..not to many of those made.
    Only for 1 year i think...2005?
  10. Afaik they made this one to commemorate the F1 championship of 05 with Fernando Alonso hench it's actually a R25 (2005 F1 car was the R25). It has that sticker in the rear side windows showing the commemoration. It's definitely a 2006 model. We had something like 50 blue ones and 20 black ones imported to ZA. The R26 obviously shares the name of the 2006 F1 car which they won the championship with again.
  11. :grinning:This is mine..2007 R26.
    coetseejj.rd likes this.
  12. B-E-A-utifull!
    Really wish my paint was still in this good condition. Car is parked in the sun at work for the past 4 years!
    Bonnet has two sunburn spots with clear coat peeling. Still on the to-do list to fix.
  13. Came 2018 and the car needs some loving. Weird clunk noises when going over small bumps especially in low speed turns.
    Ordered some Powerflex bushes from Driftworks in the UK. Import tax and duties almost killed me.
    First step was to install the engine mount inserts. Main mount, bottom mount and gearbox mount inserts.
    The gearbox mount didn't want to come off, so sparyed some silicone oil in there and then wangled my gear puller in to hook the sides. I really did not want to remove the whole mount.
    Screwed the nut onto the shaft and left a little bit so the puller shaft could rest on it. Then just cranked the puller until it popped off.
    3346c7450600fded243c51f53f4e1524.jpg 7a3f85369f71a6b9420ccdfc1ef06257.jpg bf2b84bc549f777de9e089086141ca8c.jpg a593c613085b6c4c14450485385804d0.jpg d9394c071e9b6ea1722a554eefd21dbc.jpg 6681c4ab34376a9b00cfcac88d57c9f7.jpg 5b22b18d21ac2409eafcbd3c3ed9c512.jpg
  14. This past weekend it was time to fit the rear axle bushes. Passenger side (left) is quite easy to do since nothing is in the way.
    The driver side is a lot more complicated. Have to disconnect the handbrake cable and feed it back out of the bracket which is welded to the subframe bracket.
    Then have to remove/unscrew to brake hardlines to get an unobstructed path for the bolt to push through.
    Put the bushes in freezer before you start. They just slide in when shrinked due to cold.
    Watch out that the bump stop doesn't get caught in the spring when reinstalling the axle bolt. Mine did but just popped it out with the rubber mallet...
    Pics of left side only(will ad rhs) :
    c0684e7ef06ad030fd77e5d6e4703c19.jpg c9d8a520d8ebcb2cd02d564a5902281d.jpg 2c9798e90b5a92f5f3563ab2491b2538.jpg a6d511880cba0968f1bf9f46a38220a0.jpg 1a4aa8606352ccf1a2e89ce047d388ec.jpg 6004012ea2704892ada7b4b0116d14b4.jpg 8ea0354f749f7aa23e021865187c270c.jpg d33217eb5a841378cb2c7f28ccb95c91.jpg 111ddd407911fbdc76c466bd315d0093.jpg 6f312a40b0ca229e5893fbc3db4a363a.jpg 0a2c89f094cc5b41afd77ed48f267f8f.jpg a2f0e244dc66dd0b81f18e8b0b195b9a.jpg bcdc75f20302368c157e726435a4bbba.jpg 4297e994d3de378920dc87c10c8bc856.jpg 6848482d79270f7f825495f6cfed5f1d.jpg 7b1345d361458e6557ef7db1f7e5a64a.jpg 03dff32b8f4af9eb01e98e42b52f274c.jpg 98abe39c7f7bc7dfe4f6adf9e71904d8.jpg a023396af5700855512e960a55189650.jpg
  15. Pics continued(lhs) fc3aea4ac821cb4c64b44ef0b9b8b545.jpg f0eb986a668e8647a4efceb2385f7681.jpg 378d91061087cbe8d5997482596aa114.jpg 0e04e6a3f87fb86c06cd79dddaa96de3.jpg 78d24a0599e9dc7a346fe0d4828e225c.jpg 9aed305ed0a02c4c5fc616cd09362bbb.jpg 949640f0860366a59db1b23685add679.jpg
  16. Lhs more d242dc1b22a780e992e6f44cb360c6e5.jpg f27ccdacde133c89dd8fc28c1fe617f0.jpg 5a54668ebc666629dbb8f9c16800f137.jpg
  17. Rhs.
    Brake fluid reservoir went empty during this sides install. Luckily I was able to bleed the brakes without any issues. Maybe try to close the hardlines somehow... I had nothing so it just dripped into a bag. Took 500ml to refill res and another 300ml to bleed all air out.
    Might be due to it being the rear brakes and not the front. ABS still works 100% and no brake error on dash. 4fcf862678cca338b5ab8731fb77cefa.jpg 11026ff054e6c6c6dfe573a6df504098.jpg f82495d9d4af98fabc93ac8d2158ab89.jpg d864a5e0ab89e7619141c95d3c50e0d9.jpg 4494e1b0803952e6305fe3fa099d06bc.jpg f7765221b6ebf721f78e53d766e106a7.jpg
  18. Found an older video on my laptop of the exhaust sound.
  19. matt e
    can you notice a difference with the powerflex rear mounts?
  20. Completely forgot to report on these...
    Been installed for just over a week now. I cannot feel any direct difference from the rear but the one thing I did notice was when going through a diagonal rut in the road like those where bridges are connected to the rest of the road.
    With the rubber bushes it was quite a severe sound when going over those kind of things. With the Powerflex it's more like a muffled thud now. That is the biggest difference I've noticed thus far.
    New tyres and front end bushes still need to be done so cannot really push the car atm.
  21. Yesterday was subframe day.
    ARB Powerflex Black and control arm bushes, balljoints, tie rods and rack ends.
    The property I rent a house on's son has a workshop on the property and gave me permission to use it. This was the first time I did not use axle stands but a proper lift.
    Don't have step by step photos sorry, we were pressed for time so only took a few.
    Car on the lift: 7b2b8ef6cc0760484513531d6f479e03.jpg 0a6c65b48f6349353af8ab70bfe53ea1.jpg
  22. Removed the caliper and disc.
    The to get the balljoint out I did not have a tool that fits so gave it some silicone oil spray and cranked the balljoint nut loose until it pressed against the turning knuckle bolt head. Kept turning it until the balljoint popped out. The balljoint's nut is mild steel vs the high grade knuckle bolt head did no damage to the bolt head. It's easier to do like this than remove the brackets 3 screws.
    The left hand side balljoint and tie rod was pretty knackered. Tie rod's boot was torn and had a lot of play.
    Did this on both sides. Then removed the arb droplink from the shock only. No need to remove from arb when pulling sub out.
    Then remembered I need removed the steering column bolt so down came the car and since it was on the lift it was so difficult to remove that bolt. If ever doing subframe. Remove that steering column bolt first when car is not on something where you can't open the door. 24fbd8c8308398bff930d1d76d97773d.jpg 3915eaccbc37d4945584a4a077f91a4b.jpg 0d464c4fd27d2f0522b7cca09e69b456.jpg 824d443230d9074876313676a29b1ac5.jpg
  23. Once we removed all the components holding the subframe to the car, the car was lowered, table put underneath. Final subframe bolts removed and then just raised the car, leaving the subframe on the table.
    Now it's easy to remove and replace everything that need replacing. 4463481879d8311e783ac2c6d0014eac.jpg c91d356da7f7517a5378f83e16e3e52d.jpg
  24. New balljoint and bushes. Here the photos really got to a min. That all I have. It was fun to do. I rather remove more and work easier than trying to just replace something on the car.
    Now just to get the new tyres fitted and geometry aligned!
    e5956221e6f0e5d5fe645f982717654b.jpg 945ff6670b75a2a416da2761d6d2b9c1.jpg 8a1b6e43f0b4321b5df850d24d33d822.jpg 51bd8ce105dbd0fd8bdbd23d3d54c57c.jpg 8bf7d2f2af6370a33d3ee3dd513aee37.jpg
    trickmansa likes this.
  25. Were did you get all the parts from? I am also in SA.
  26. Got most aftermarket things from Masterparts in Cape Town and then the Powerflex goodies was imported from Driftworks.co.uk
    Paid massive import duties though. R2200 just on duties. But driftworks wave the UK tax when they export so it kinda comes down to same as buying in the UK.
  27. Went to watch the F1 at my friend's house about 12km away and took the car for a drive after yesterdays parts being replaced.
    Before doing the engine mounts and suspension components, when lifting off the throttle and going back on it in a sea saw motion, there was a lot of movement that I could feel, it was like a lot of slop.
    After the engine mounts I hoped it would go away, but alas, there was still this slop.
    Happy to report that after the balljoints, control arm bushes and rack ends plus tie rods, the slop is gone. I can go on and off the throttle without any jerkiness.
    Tomorrow having the new tyres fitted plus alignment done. Had to buy budget tyres but the last set of budget tyres did 45k kms so not too concerned.
    Chris79 and trickmansa like this.
  28. New tyres fitted and alignment done!
    Everything is still within spec! I'll post a pic of the alignment printout later.
    So glad I replaced everything before doing tyres and alignment. Now I have peace of mind.
    Now onto the crank seal leak. Seems to be the timing side leaking at the bottom just behind the timing belt. 6580ea1f82a918b372d226d644af1ae5.jpg 52861b7c99a96619ba8d9be73cb39ee7.jpg
    Chris79 likes this.
  29. Look at all the oil gunk buildup from the leak. ac7a33a9d01a7a2c5c3b56d98294542f.jpg
  30. Geometry sheet after the suspension component replacement and Poly bushes installed. f7a5f714a7a9330268014335d445e351.jpg
    Mikey4410 likes this.
